amp and sub problem
name of the subs and coil config..also what model# amp.
does anyone know how you would hook up 2 subs to a 3 channel amp?
its possible but dont do it. pointless and retarded. get urself a mono amp....or if you have a 2 channel laying around but seriously just get some cash and buy a mono.
well as of right now im just running one sub but im running it on the channel A and its bridged from the two speaker outputs I dont have it running throught the sub output
but when i try to do the same thing on the channel B with the other sub it dosen't work
if all three channels are the same, then run 1 sub off of 1 channel, and do it twice leaving one of the channels empty, or do the right thing and get the proper amp for your setup
