Alt sites for the Ford DVD manuals?
Just an update in case anyone else has the problem of not being able to download the dvd iso torrent for the 2003 LS.
The problem I was having was from my Dlilnk router not letting the torrent client communicate. I supposedly had to allow Upnp to work (which I did) still didn't work. The easy solution was to connect my cable modem directly to my computer for a night, and bypass the router.
I'm sure it could be setup to work with the Dlink, but I didn't feel like reading much last night!
After bypassing the router, Its taken about 14 hours to download.
im curious, did you get the EVTM to work on it? I havne't had any luck pulling it up
I'll hopefully be able to tell you soon. I still have around 3 hours left on the DL, then I have to did around and find a DVD to burn.
I did the 93 manual for my ford escort, with no problems but I think this torrent is a bit different.
I ended up downloading the entire 00-04 dvd but it exceeds the size limit for single layer dvd-r's so I'm having to download the individual model years I need. Just be sure ebfore you start you're download your not going to be able to fit the entire 00'04 iso on a single layer dvd.
I haven't found the EVTM exactly, but I know that the wiring diagrams give a script error whenever I try to pull them up. Good thing the school I teach at has Alldata!
The ISO won't fit on a standard DVD so I just loaded the image as a drive using Daemon tools. I ran setup and used the last 5 digits of my vin as the PA code.
Working fine so far, except for the wiring area...
