Alarm!
lincolnx2
Ft. Campbell
My alarm goes off for no reason, I called the dealership and they said strong winds would set it off, but i don't get very strong wind gust in my garage. I have a 03 LS, any possible suggestions.
the factory alarm does not have a shock sensor, so if it is a factory alarm there is a problem with the car (probably a door trigger) if it is an aftermarket alarm then it could be a lot of things, most good aftermarket alarm have a report menu that will tell you why it set off the alarm (door triggers, trunk triggers, hood pin, or shock sensor) this will help narrow it down.
