Airbag Light Code P0153
Mussolini1996
Missoula
So I took apart my dash to see if I needed to replace the airbag bulb, and to my "surprise" there wasn't even a bulb there, so I put one in. Now my airbag light won't stay off. So I scanned the computer and the code I get is P0153 Circuit Slow (Bank 2 Sensor 1).
Does anyone now how to even attempt to remedy this problem??? Does the "P" possibly stand for passenger???
That's an O2 sensor code.
The airbag system is completely separate from the OBD module so you cant read airbag codes with a scanner. When you start the car the airbag light will blink several times and if there is a problem it will then stay solid. The blinking is the airbag system displaying a 2 digit trouble code. It will blink a few times then pause, then blink a few more, then there will be a longer pause after which it will repeat the process. It will do this 5 or 6 times. Just count the blinks and write them down to get the code.
