Air ride question
1sik32valve
San Bernardino
I'm at work working on this 2001 town car and I'm supposed to replace these air springs. Step by step
1. Turn off air ride switch.
2. Jacked up car.
3. Pulled clips on top of springs.
4. Unhooked air supply line.
5. Remove and replace spring
6. Put clip back on
7. Put air supply to spring
8. Expanded spring as far as possible
9. Raised the differential up to the springs
10. Turned switch back on hear compressor but not rising after back completely on the floor
Thanks guys.
did you replace the solenoids if so did you replace th rubber o ring if so did you lubricate it properly if not could possibly rip and leak when you raised the axle did you hear the new springs click into place also is your compressor good? a few things to ponder
