Air Ride on 1996 mark Viii all jacked up
1996mark8green
hopkins
Came out to the car yesterday and it is air-ed up as high as it will go , I cut the air compressor off , when you turn the car on with compressor on it runs and times out . looks like a 4x4 right now . Iam currentlly in oswego new york and its like 18 degress how can i fix this please help thanks Dave
Cold
Mine has occasional issues when it is cold out. Probably moisture trapped in the system and as the Frat Man said, can't vent. Sometimes we all need to vent.
What it most likely is is moisture in the system and the cold weather has frozen the vent solenoid in the compressor in the closed position. I would try to find a warm garage for it to sit in for a few hours and see if that helps (if you can) to allow the moisture to thaw a bit to allow the vent solenoid to become unfrozen.
check to see if one of your front height sensors has become detached. happened to me.
problem solved
Thanks for everyones input , but 67 hit it right on the money the front passenger side ht senser had come loose at the top and now that it is in place the car is back to the right hight , thanks again dave
