Air Ride And Ford Shop
Glorywagon
Greenbrier
Well changed the Air Suspension module that we got from Jamie today.The front end seemed to come down but the rear end is still high.
The car for some reason seems to steer better.The check air ride light when we started car it come on pushed reset and stayed out (For now).
Also the old Air Suspension module someone had it apart before and resealed it.
Ok. When the error comes up the system is off until the car is started again. All reset does is clear the message, but the system will not do anything no matter how long you drive the car.
As I think was mentioned, check the rear sensor and make sure its attached. The modules dont usually go bad, they are a solid state computer. You have a problem with:
relay
sensor
fuse
broken wire
relay
sensor
fuse
just drive it till it blows out . then put an conversion kit on it.
broken wire
But the Suspension module was bad also because now the front is working. ok Ill check . Thanks.
relay
sensor
fuse
broken wire
If it was brain dead then It would not test. (after all someone had screwed with the brain box before)
So now sense I replaced the Brain And I have ford run the same test should"t it tell whats wrong with it now?
After all it did lower the front now and steers like a different car.With the front end up also wouldn't it screw with the steering.
Help Please
:confused:
Yesterday I replaced the Air Suspension module. Today the cars front end won't come up Setting on the ground almost.
The rear end is still up real high.
started the car and the front didn't come up. The car stayed up for 2 or 3 days till I changed the Air Suspension module. :confused:
Have you gone to Eddie's site and gone through his trouble shooting page?
Well, good luck.
Thank You I just gonna convert it over to spring ride $375.00.
I done spent $90.00 and now its worst then it was.I can't even drive it now.
If that don't work it will go up on the hill with the other junk Lincoln's (parts Car):)
Thank you all for all the information. Danny
