Air bag light
MobyDick
Houston
My air bag light flashes and I think it may be a loose connection. Can anyone tell me where to to look so I can check it?
Tell us the flash pattern, then we can tell you what is probably wrong. One common fault is the clock spring. If that fails, then cruise can also become inoperative or sporadic.
Ok, thanks. I think that may be the problem. The horn works but CC does not. However, based on my research it appears that it is possible for the clockspring to be bad even tho the horn still works. Do Ford dealers still sell this part?
Yes, but WAY cheaper by me, I've got several, what year Mark?
