aftermarket linkage/clutch?
None out there that I've seen, though I'm sure you could beef up the stock clutch with a little research on it's spec's and interchangability with other Ford clutches. You'd also need to beef up the tranny somehow if you get the engine to put out more than 250HP and the acompanying increase in torque.
The shifter has such a short throw now, I'm not sure that much would be gained by putting something else in.
