advancetrac light flashing
JTRUDEL
Niagara
since most of you guys are knowlegable i thought that i would turn to you once again with ANOTHER problem that i have stumbled across with this car...that i just cant seem to sell .......anyways i was on my way home from work this afternoon and i happened to look down at the cluster ..i dont remember hitting any bumps....nothing out of the ordinary happened on dry pavement.... and the advance trac light was flashing theres no messege in the message center everything seems okay you can still turn on and off the adv.trac the ABS still works everything seems okay that way. i have been reading on here for the past hour and nothing makes sense i checked the brake fluid unplugged both pressure sensors on the master then the light stays on solid and that message center says CHECK ADVANCE TRAC plugged back in it all seems okay except for for the light flashing ........the little car with the squigally lines all i have to do is turn the key to the on position and it will start flashing if anyone can help me out with ideas tomorrow it will be going to the dealership...... thanks
JUSTIN
