Well I've seen some of the posts. But I am still trying to figure things OUT? My buddy put his scanner on & pulled THOES codes C1288 & C 1289! He cleared the memory & now. NO Check Advance Trac but a flashing light on the dash ALL the time? Dident do that @ first just every once & awile. Check Advance Trac & a light on all the time not flashing with it? Reflashing? Or what? Can Anyone Please Help???
Sounds to me like your buddys scanner isn't setup to read/reset the codes correctly. I would have Lincoln clear the code and see if it doesn't go away then.
Well when I first seen the Advance Trac on the display the little car @ the top of the dash was on steady. Every time I turned the car off every thing would go away. I would not see it for awile & it would come back every couple of days. Then my buddy put his scanner on it & pulled thoes two codes. It was a vary good scanner SnapOn big $! Well he cleared the memory to see what would come back. The two codes came back! But Now insted of the Advance Trac on the display & steady light. ONLY the little car & now its flashing. It is also on every time i start the car now? I dont notice any driving problems @ all.
