92spi
good evening- 2000 lsv8. on a cold start (relatively speaking), should the radiator fan speed drop back to low after turning on, then turning off the air conditioning? had to replace the actuator valve (again) because of no high speed function, and fan refuses to return to low speed until engine is stopped and restarted. just turning off the air does NOT do it. temp gage is still bottomed out. and a long cold chisel worked well when the solenoid part of the valve spun off and left the hydraulic part. lotsa fun. thank you.
