Accessory Bracket Bolts
ninja jt
Northern IL
Can anyone help me identify which bolts go into which hole for the brackets that go behind the power steering pump and the fan pump? I'm finishing up with doing the timing chain tensioners and I thought I did a good job bagging and labeling each bolt that came off the accessories and these brackets but I'm having some difficulty putting some of them back in. I've tried to find an exploded view but haven't had any luck. I know there are M8x60mm M8x64mm and M8x85mm.
