AC Troubleshooting
GMAN
Spring, Texas, United States
My compressor isn't kicking on like it should. The manual doesn't mention a fuse. Is there one that controls the compressor?
Did you try jumping the plug at the pressure switch to see if it was low on freeon?
I'm curious how well that stuff works, update us when it leaks down again
if you put 2 cans in your were completly empty. Keep an eye out for a leak. AC systems don't normally loose refrigerant.
