AC questions
RedHotMark96
SE MI
Last summer I filled the refrigerant for the AC. For a few months the AC would blow cold air, then it gradually started to get warmer.
Now I have no cold air on at all, but the heat and defrost work just fine. Only other thing I've noticed is that the fan blows much stronger out of the center vents than the one by the door.
I tried to fill the freon again but it was still full.
The compressor cycles on and off with the AC on, I only get hot air out of the vents.
So is this a blend door problem, a plug in the AC line somewhere, or something else?
