AbrahamLincoln
ok, i recharged my ac about two months ago with r134a or whatever its called, i don't believe i filled it up all the way but it was enough to get the compressor running and blow icey cold air.
Now on a sidenote, i have had some evap issues... i capped the end that comes off the throttle body because of rubbing issues that tore up some of the lines that run back to the tank because of my drop and tire rubbing issues and i didnt want to smell the gas or have the leak, so for now I have yet to fix that... i dont know if that has anything to do with the a/c or whatever but I just wanted to throw that out there.
ok the a/c compressor turns on but on full blast its not as icey cold as it used to be on MAX. However, it seems that if I manually turn the fan down a bit it will blow icey again. When its on full fan it blows somewhat chilled but no where near what it used to be.
Question: I'm guessing I have a leak, because I had to add refrigerant in the first place but I was hoping the sealer stuff inside the can would plug it up. Where is a common place to look for a leak?
also when i turn off the car and i have the hood open, i hear a slight leak only for a few seconds but I'm guessing that's the system venting after the car is off and could be normal.
i guess i can go get another small can and add it to get it back up to par but im afraid another two months bam ill be stuck again but luckily summers up here arnt long in north east Pennsylvania, but I would like to fix it so if anyone has any ideas
it could also be that now that its getting hotter, and since I don't have the pressure up all the way to the correct level (im going by what i read here about 37 psi or something) - i just went by the guage that comes with the can to be in the normal level... that possibly that now that it's hotter I need to get the pressure up to that specific psi
