AC Condensate Drain Location
TooManyToys
New Jersey Shore
Hey guys, it's been a while since I was here. The LS has developed a situation of high humidity on the windshield on first startup, typical of water not draining from the A/C housing. Can someone point me to where the drain port is on this vehicle? I've tried to do a search here and on google without any positive results.
Thanks
dont know about the LS, but with a lot of cars, its on the firewall, kinda low, usually on the passenger side.
It's hard to get to on the LS, you need to remove the right-front wheel and fender liner. There was a TSB about the starter battery cable tether blocking the drain port and creating a musty odor.
What's this? Another example of poor engineering? Heh heh.. thanks on that, my LS has a musty smell all the time. I will go investigate this, and correct yet another engineering fail. :D
