Thanks Josh for the reply. The ABS light is the only one on,when the car is started up both brake lights come on for the check, then go out.When the car speed hit about 65-70 mph the ABS light only comes on, and will not go out till car is shut down. I also do not have ABS system working when both lights are out, did some hard stops and front brakes locked up, all done at different speeds 30-80 mph. I have replaced both rear sensors (new),ABS computer in trunk (junk yard), had brake job don about 2yrs ago.Do you think it could be the wheel sensor rings?. The reason I asked about the master cylinder was I saw one in a 86 at a junk yard that looked new, hell the whole engine looked new. Shops around here won't even look at a old car with a ABS problem,the dealer did not even want to take it in said it will run me to much, that was a first for me.Sorry for the long post.
Thanks Alan
