Abs problem solved
ONLYTONY
East Hartford
Had a prpblem on my 95 with ABS. First I checked rear sensors, all ok. Checked front sensors, and there is the problem. Last year I re-did the front end, using parts that you can lube. Both front sensors, and sprokets covered in gook. Sprayed with brake cleaner and all works well. I guess I'll stop using so much lube. Turned out to be an easy fix.
gook
I must have gotten that gook after 5pm, because I dont remember running any asians over, and no gook on front bumper Semper Fi
