abs light what to do!
vicls
Winnipeg
HEy guys so its super cold and i used my car starter to start my car for the first time. It started up fine and everything but all of a sudden my abs light is on dunno why was never like this before... what is the abs light?
Its for the Anti-lock Braking System, if you have a Autozone or any other auto parts store near you see if they will pull the code for you and come back and post it here, im sure someone can tell you what it means ;)
are you saying your battery was dead and u used a battery charger in start mode to start it???? If so a dead battery wilol cause all sorts of lights to come on. when mine was real low my abs , traction , check engine and even tail light warning . so if that is the case charge your battery overnight and see from there
