xford
What is the best protection to put on the black metal B-pillars? Wax or something else?
Can rear stainless steel brake lines still be purchased anywhere for a Gen2 that would not require modification to install?
Is it normal that the AC unit makes a slight gurgling sound inside the cabin? Sounds like refrigerant going through the condensing tubes with key in ACC or @ idle.
Thanks for any input...
