Anyone have any suggestions when it comes to doing the "ground" for the head unit? I assume that that big bar behind the deck is a good place to go for but i would rather know for sure....
The Metra Kit i purchased has a wire labeled Chassis Ground... can i just ground all wires to here???
Anyone able to point out a clever spot for a ground in the trunk?
Also on the SWI-PS, for powering it....just splice into the decks red "Ignition/Switched (+12v)" wire? Then connect the ground the same place as all the other grounded wires?
One other question, not sure if all LS's like my LSE, have the amplified speakers in back such as mine does. (i purchased the Metra Wiring Harness)...
This is a white headed connector piece, and there is one set of RCA (plugged them into the 2ndRCA output coming from the deck labeled "rear output")(subs RCA'd to the Sub Out pair). Then there are also 2black/white "amplifier ground" and 2 blue/white "amp turn-on" wires.... I thought it might connect to the blue "Remote System Control" wire that is used for my sub amp...but i was not sure.
Any help would be appreciated. Ive installed decks/speakers in my other cars and friends but this Linc has stuff ive never dealt with before and i would rather not fry anything knowing how electrical this car is...
If i can get these few questions answered i should have it done/installed over the middle of the week!
