A/c Vent Problems......
JRALVARADO
Phoenix
What's up everyone, this is my first post but I've been coming to this forum for about a year now. First off I have an 03 Lincoln LS V8 with about 26,000 miles on it. I just noticed that when I first turn my heater on the air blows out through all the vents like it should. Then after about 2 minutes it stops blowing through the 2 center vents, but still stays on. It starts blowing like crazy out from under the steering wheel vent. As soon as I turn off the car then turn it back on it starts working fine, but then after about 2 minutes it does it again.I had an Eclipse in dash installed about a year ago and the A/C worked fine afterwards. But I had an amplifier hooked up about a week ago and ever since then I've had this problem. Just wondering if it's something I might be able to fix myself or if it's something I should take in to be checked. Any help/advice would be greatly appreciated. Thanks.:)
Don't know what the problem is. You might pull your head unit and make sure all the connectors are tight. Were did you run your remote wire from for the amp. If you tapped into the cars harness you may have a problem there.
