a/c pully removal
lincolnboy
tx
what tool is needed. i have a pully puller but couldnt find if i can use it.
No you need something like this HERE One pulls it off and a diffrent one installs it back on. Dont forget to set the air gap when you re-install the clutch back on.
The hub and pully come off with just a single little bolt in the center, and a snap ring holding the pulley on. Be careful not to lose the shims inside the hub if there are any.
You'll then need a puller to get the clutch field coil off and back on, the one jrherald linked doesn't do the FS10 which we have, though it may still work?...
+1
when I did my last pulley I didn't even take the field coil off
No sh*t, like i said before i posted the first link i found so the OP didnt try to use a pully puller on an A/C clutch and to point out theres a difffrent tool of that job...maybe give him an idea of what to look for.
Lol
