the compressor is now making a grinding noise and found two melted rubber pieces from the clutch on the ground.the ford dealer said it's not pumping anything and there's probably metal shavings in the system now.but I guess for now he's(me)just gonna put a bypass pulley on it for now till he has the money to fix it.
the compressor makes a grinding noise when spinning it by hand so it's junk.And there is metal shavings in the filter.He had Ford evac and install the pulley for $103 not to bad.
