A/C freon leak
pragmatic
Tuxedo, NY
My air conditioning was not working well last week as I left for vacation (99 and humid outside, barely cool inside). While checking it out by the side of the road I noticed oil where compressor outlet line attachs to the condenser (top driver's side of the condenser). A quick charge with some 134a (into the low pressure port on the compressor) restored the cooling. So far (a week) the a/c is still working well but I'll need to fix the leak.
Chances are its the o-ring in the fitting, but has anyone else had a leak develop at this location? If so was it the o-ring or have there been problems with the condenser or line fittings?
The car is a 2000 V6 manual tranmission (as if that matters).
Thanks
I know its not as exciting as 20 inch wheels but surely someone has some else has experience with freon leaks caused by failed o-rings, bad condenser or faulty high pressure lines.
I'm not an A/C expert simply because I haven't had to mess with mine (knock on wood). However, I'm sure someone here has experienced what you are seeing. Was the A/C not cooling on both sides or just one?
It's probably o-rings. Unless you have all the special tools to work on a/c properly, it's not a DIY job. First thing to do is double check that the leak is at the fitting with a good leak detector. Then recover the system, fix the leak, evacuate and recharge, then leak detect again.
I think i Might have a leak as well.... were can i check it? and how much should i pay to repair it....Having no AC sucks....
I had an A/C problem with my car. I can't remember exactly what hose was replaced but there was a leak. I went on vacation to GA from WI and around IN it went out. Drove about 500 miles with little to no A/C in 90+ degree weather.
Once I checked it out, the mechanic showed me the hose they replaced and it looked like it had deteriorated somewhat on one end.
Didn't seem like much IMO, but A/C worked perfect afterwards.
I'll look for my service write-up but I think it was a couple hundred for the part plus 30 or 40 for the refill of refrigrant
Oh yeah, the service tech guy was not very happy about the LS and said it was a pain in the *ss to check the whole A/C system for a leak and then to get through to replace the hose.
Altogether, they worked on it for about 3 hours. So it doesn't seem like a DIY-type of job.
