mmm
2003 V6 LS
Has anyone ever had this issue:
When I turn my A/C on it will blow cold air but only blows at a high (max) fan speed. Pressing the fan speed up or down on my Temp Controller (DEATC is the formal name in the manual) does not adjust the flow of air. The temp controller indicates a change in fan speed on the display, but the air flow coming from vents remains at max.
Also, once I turn the A/C on using the Temp Controller I can't turn it off.
If I press the "OFF" button on the Temp Controller, all the vents electronically close (as they should) but the fan which blows the air through the vents does not turn off. So I have the equivalent of running the A/C at max fan speed, but having all the vents closed. Loud.
The only way to turn off the air attempting to come thru the vents is to turn off the car completely. The fan continues to blow max air for about 30seconds after ignition if off and then turns off. It will remain off even if I start the car again, as long as I do not turn on the A/C with the Temp Controller.
notes: 1) I can control the temperature of the air coming out by using the Temp Controller and it seems to slightly adjust fan speed as if it were running in "Auto" mode. So if its 75 degrees outside and I set it to 75 it will blow less than max.
2) All other controls on Temp Controller seem to work just fine.
3) I tried disconnecting the battery and reconnecting to see if a reset of Temp Controller was needed, but it did not help.
Is there a specific relay under the hood or in the trunk that could stick and cause only one fan speed??
Thanks in advance for any help.
