MatthewDavid
OK I've put a few threads up about my problem but I figure I could ask a better ??... ok I changed out all the boots in my car and spark plugs... it's running really bad... it still has a misfire on cylinder 5... but now it's #6 too... I think it's cause when I pulled them the boot and the spring in it was all stretched...
my ??'s are one can I just replace that spring?... is there any way to test the coil itself... I know you can swap them around but the harness it's on isn't very forgiving...
also there's oil in almost all the cylinders... do you think I should change the gasket right away or do you think I have a little time... it doesn't look hard to do just it snowed here and it looks like I have to pull a lot of things to get to them...
thanks... any info is appreciated... sux cause besides this my 97's perfectly fine...
