nothernconti
Help, please, got electrical probs.
Fuel pump not running and not getting enough power (tests at 6volts), while plugs are sparking.
Pump runs if given direct 12v, but then sparking halts.
Inertia switch tests ok.
If ignition is left in ON (without starting) the Constant Control Relay Module's relays switch back and forth rapidly, have no idea why?
Replaced the constant control relay (also know as the engine control relay) and still having the same problems. The problem must be downstream of this module, any ideas of what it could be?
