632 Code
mistermaclincoln
Tacoma
Was just driving down the steet and my motor started blogging down and the CEL light pop up and as the motor throttles down the CEL Light goes out and then comes back on when I hit the pedal. Got code 632 and my overdrive switch is the problem. Where is the overdrive switch? You know I think my tranny is on the way out even though I can still use the car. Need to address just getting a new running gear and start over. Your thoughts!!!
Thanks
not your problem. keep looking.
632 is what you get when you don't cycle the overdrive switch during the key on engine on test.
