5x4.5 hub swap
87TTOPGT420
South Woodslee, Ontario
I have everything for a complete hub swap rotors front and rear, rear hubs pressed into spindles with new bearings, front hubs, also have brackets I made to run cobra rear rotors what would something like this be worth it's pretty much ready to bolt on and go
Why I ask I could potentially want to sell this
Honestly? Not much over retail (or even Max's prices).
Pressing the bearings into the rear hubs is less than 40 bucks at a good shop. Furthermore, you didn't specify what kind of bearings. High end good bearings, or Chinese bearings.
Who made the hubs? Are they FORD OEM or third party? Again, Good stuff or Chinese?
I think your strongest selling point is the rear caliper brackets.
Good bearings rear oem rear hubs midline front hubs
First off, I'm not trying to blow the chances of you selling this stuff... however, "good" bearings and "midline" hubs don't tell anyone much.
What you may consider "good" and "midline", most may consider junk... and vice versa.
"Good" isn't always good enough and "midline" isn't always the best thing to use for a critical piece such as a main load bearing part.
i agree and where are the pictures? without pictures people wont buy :q:q:q:q honestly would u buy a car by word of mouth and u get there and its a POS/?????
I got them from my works part supplier they are all good quality parts I don't play around when it comes to wheel bearings
And I'm not bs'ing. I wanna sell this stuff if it fetches the right price
Rear hubs pressed in are $40 per side
Rear cobra hubs $130 plus shipping
Front hubs $75-125 depending on quality
Cobra rear rotors 30-50$ per side
Front rotors $25 each
Custom brackets about 3 hrs labour plus hardware and material
I'll post pics of everything when I everything up
And ya I understand pics are key and I'll get them when I have a min
So with all work done $400 plus shipping seems realistic atleast IMO
Calipers are not included all parts have less then 5000kms 3000miles
With the exception of the rust on the rotors from sitting everything is mint but that's your opinion 10 min a rotor with a scotch Brite pad before install and they'll look like new
