40mm Offset
The that little offset the wheel will be flush with the fender well. You might have some rubbing problems.
PGA2B said:
Do you mean inside wheel well or outside wheel well?
It will be the outside fender. I am right on the money with rubbing and had to bend my fender lip. You will be an extra 8mm extended outward than me. You will definitely have rubbing with a 40mm 8.5" wheel.
use this calculator here http://www.1010tires.com/WheelOffsetCalculator.asp
Use the stock 7.5" 60mm as a reference or my 8" 42 mm and dont go any further out than what I have or you will have rubbing.
I will be using a 45mm offset
