4.10 gear et difference?
K*A*B
pemberton
i'll have the rear apart anyway to install the trac loc , and i have a set of 4.10's just sitting here
i wasn't going to change the gears because the .2 improvement i've seen from the 5 other cars i've owned , just doesn't seem worth it
but if it is going to be .5 then i would do it
so has anyone done any type of testing to confirm a big improvement in et with 4.10's ?
i did like the improvement from 50-80 in my 88 mark7 with the 4.10's
I don't think you will see .5 where your at with the spray. I say if it ain't broke don't fix it. You have a killer NOS set up that will be consistent. I say for what your doing leave the stock gears.
What times do you run now? Considering that nitrous is not used all the time, gears can only improve your everyday driving experinece IMO. I would like to see some before and after numbers as well.
i'm looking for better N/A et's , i don't think they will do very much on the bottle
basically i want to run in the 13's pretty consistantly N/A
i haven't raced it yet since i put the trans back in , but it shifts perfect hopefully worth .10 and the car deffinetly runs cooler now
i hope to go to atco thursday , hopefully a 14.40 - 14.50
150 shot , 13.30 @108
with a posi it and the trans actually able to shift into third it should run in the 12's , i'll find out this week
when i get a timing adjuster , i'll try a 200 shot
