30k service
jiggajatt
HTOWN TEXAS/ BUT STILLA BAY AREA BOSS
I was quoted $996 to do my 30K service from a independent ford certified shop called the Ford Doctors. The dealership was chargin $549 but didnt include even half of the things this guy is going to do to my car.
This is what is included
http://www.forddoctors.com/rec30000.htm
and this is his website
do you think its worth it?
my car has 46,985 miles on it and its an 05 i know im late for my 30k:(
personally i wouldnt do it. seems like way too much money. i had my tranny serviced for $69. radiator can be done for about the same. you can top off all fluids yourself for cheap money and have extra left over for when you need it. and cross off all the things he put as just inspect. inspect is nothing you will have to pay more if it need to be replaced or fixed. and most of the other stuff like timing adjustment and idle adjustment you wont need. sounds like a waste of money. you can save hundreds...
Doc's 30k service
Diagnostic Inspection / Emission Analysis
Change Oil and Filter
Top Off ALL Fluid Levels
Fill Windshield Washer Reservoir
Change Rear Axle Oil
Change Manual Transmission Fluid
Change Automatic Transmission Fluid, Filter & Gasket.
Service Transmission Torque Converter
Visual Inspection of Fuel Injection System
Inspect Drive Belts and Hoses
Lube Linkage, Doors and Hinges
Test Electronic Engine Control System
Clean Battery Chemically, New Terminal Pads
Pressure Test and Leak Test Cooling System
Flush and Fill Cooling System with Proper Anti-Freeze
Visual Inspection of A/C System
Adjust Ignition Timing
Inspect Thermostatically Controlled Air Cleaner
Replace Spark Plugs - Motorcraft Platinum Extra
Inspect Ignition Coil Wires
Inspect Air Injector Reactor System
Inspect Wheel Bearings
Change PCV Valve and Replace Screen
Inspect Distributor - Advance and Base Setting
Inspect Steering Gear Play
Inspect Front and Rear Axle Oil
Inspect Exhaust System
Adjust Engine Idle Speed
Adjust Tire Pressure to Ford Specifications
Rotate Tires and Balance - All 4 Wheels
Inspect Tires and Wheels for Wear and Alignment
Inspect Brake Pads and Shoes
Inspect Brake Lines and Hoses
Inspect and Adjust Brake and Clutch Pedal Play
Inspect and Adjust Parking Brake
Lube Steering Linkage and Suspension
Replace Fuel Filter Assembly
Replace Air Filter Element
Wash Vehicle
Vacuum Interior
Clean Windows
Chamois Exterior
Road Test for Ride, Feel, and General Operation
Safety Check, Inspect All Exterior Lights
Lincoln LS 30k service
+Inspect brake pads/shoes/rotors/drums, brake lines and hoses, and parking brake system
+ Inspect complete exhaust system and heat shields
+ Inspect and lubricate all non-sealed steering linkage, ball joints, suspension joints, half-shafts / drive-shafts, and u-joints
+ Inspect engine cooling system and hoses
+ Rotate and inspect tires; check wheel end play and turning noise
+ Perform multi-point inspection
+ Change engine oil and replace oil filter (up to 5 quarts of oil)
+ Replace engine air filter
+ Replace cabin air filter
+ Replace fuel filter
+ Replace climate controlled seat filters, if equipped
+ Lubricate front lower control arm and steering linkage ball joints with zerk fittings, if equipped
+ Check battery electrolyte level
+ Inspect automatic transmission fluid level (if equipped with underhood dipstick)
+ Change automatic transmission fluid
There is a big difference between what they do & what Ford says needs to be done. Unless you feel better ($500 better) about having extra stuff done, I would not do it. Several things don't even apply.
Hell, you all ready missed it by 15k - just change the oil & pick it up at the next big service interval
i went back today to see why its so much and he gave me a list of the parts and labor
30K service 229.81
Parts:
wheel weights- 11.34
fuel filter inject-39.99
antifreeze solution-39.99
transmission kit-69.99
flushing neutralizer-19.99
pcv valve assy-9.99
synthetic trans oil-143.76
oil filter assy-3.81
diff/axle lube 39.96
parts cleaner/flush-9.99
Total is $618.62
bs stuff (i think)
Equipment Usage Fees-97.81
Tech inform 69.99
Taxes 44.37
Grand Total 830.79
Still a bad deal?
"Equipment Useage Fees"? "Tech Inform"? What the heck are those?? Wait, I'll take a guess. Rental of the equipment needed to work on your car, and time taken for the tech to learn how to work on your car! :D
I'm with FuzzyB on this one. Just do the dealer's service. I have a feeling the Ford Doctors are a bunch of quacks.
