I have a 2001 LS V8. I assume the oil pump went out. I was driving about 50mph when the engine just died. I have tried to turn the engine over by using a socket and breaker bar and it will not turn. now on to my question. I have read on this baord that 2000-2002 engine interchange and 2003-up engines will not work in my 2001. What is the major difference? Can i strip a 2003+ down to the long block and use it? the reason I ask is I just did a Catera swap using a 2004 CTS 3.2 and it turned out real well. Had to swap the oil pan and pickup, the intake, the flex plate and a few other small items.
I guess I'm hoping the Lincoln 3.9 is the same basic engine between years and will interchange by changing some of the bolt on parts.
