2006 LS code says driver side door ajar
John Cam
Rockwall, Texas 75032
Driver side rear door ajar message shows up when door is closed. Is there a fix for this? Code left uncleared runs battery down if the car isn't driven for awhile.
Does your interior light go out with the door closed?
The door ajar switch is in the door latch assembly.
If you don't want to replace it, you can short the black/orange wire to the black/yellow wire (both going to the door latch assembly) and it will make the door seem to be always closed, even when you do open it.
