nelliott500
- Transmission solenoid pack and filter were replaced as well as a complete transmission flush (100% fresh Ford Mercon V fluid)
- Fuel filter replaced
- Air filter replaced
- All brake pads replaced
- Spark plugs replaced
- Passenger side valve cover gasket replaced (a spare driver side gasket will come with the car but it's not leaking)
- Oil has been changed with Mobil 1 Synthetic 5w20 and quality filters (currently a K&N)
- Upper coolant pipe, thermostat, thermostat housing, and both coolant inlet pipes have been replaced
- Serpentine belt replaced
- Steering shaft replaced
The car comes with two sets of keys and keyfobs. I've also installed a PIE adapter on the stock radio and routed an aux cable to the center console. I installed the 3.5mm connection right next to the 12V plug so you can charge your device while it plays.
I'm asking $8500 for LVC members but I'm open to offers. This car is in good shape. The paint is great on most of the car but it has its flaws on the front bumper (typical from highway driving) and a couple nicks behind the rear tires. Also, the rear door actuators have failed. Neither door will unlock and only the passenger side will lock. They're easy to replace but I haven't spent a lot of time sourcing a pair of used actuators. If it's a big deal, I'd be more than happy to replace them if the parts are paid for.
