My wife's '03 LSV8 is having issues. Listed below are the issues in no particular order:
1) CEL on; reads code P1633. Battery is fairly new; cleaned terminals, no change.
2) Fuse #7 behind kick panel blows the instant I plug another one in. D/S power seat, power mirrors, are inop.
3) "Service Park Brake" shows on instrument cluster.
An unrelated (I think) issue is that there is a "hissssssing" noise coming from behind the instrument panel that seems to be related to the A/C. It goes away when the A/C is switched off. Also, the vent temperature isn't very cool anymore. I thought that the DCCV might be allowing hot water to pass into the heater cores. However, after changing the DCCV, I don't notice much difference in the vent temps.
I checked each fuse in all 3 fuse boxes, with nothing out of order except the aforementioned fuse #7 behind the kick panel. I'm stumped. Any and all help is greatly appreciated.
Cheers!
JD
Cheers!
JD
