2003+ Generation LS
bdj5773
Sullivan
My beloved 2001 Lincoln gave up the ghost the other day. It had 215,000 miles and a rod a started to knock. It has gotten really bad now. I'm looking at getting another LS. I'm wanting to know if the newer models have the same sort of issues as the older models. I'm looking at 2003 or newer. Do these newer models still have the notorious valve cover gasket leaks or the degas bottle cracks? I want to try and steer clear of having to do these jobs again. What should I look out for? Thanks!
Gen II is mostly different issues.
The valve cover gasket issue was resolved with the 2004 model year. Most 2003 probably have the newer gaskets by now. Of course, just like any other car, they may still leak after 100K+ miles or several years.
The cooling system still has problems with the plastic parts leaking, including the degas bottle. I think that this is an issue with many 2000+ cars. My BMW is just as bad about it. It is full of plastic cooling system parts and they crack about as often as on the LSes. (One difference is that the BWM parts are less expensive.)
I think the most common engine mechanical failure in 00', 01, was timing chains. The 02+ dont have as many problems with those.
I'm a bit surprised to hear BMW parts are less, is that OEM parts?
Yes. Example:
LS Degas tank: $168 (Motorcraft)
325i pressurized reservoir: $59.58 (BMW OEM)
Worse yet, the BMW tank is more complex. It's not what I expected either.
if your looking for more comparisons between 1st and 2nd gen Ls's, there are quite a few on this site...use google to search around... happy hunting
oh and the 03 still had some "growing pains" if your dead set on 2nd gen, look 04+
I think '05+ was where ford finally put proper tranny fluid in them. Evidently he fluid before hand was substandard and that cause a lot of the solenoid issues.
Thanks guys! Your responses have been very informative. You can get a 2004+ for pretty good prices with low miles.
