My wife's '02 LS (V8, 50K miles) has been having some small troubles lately and I wanted to ask for advice.
1. Yesterday, it started experiencing a rough idle and giving a Cyl 8 misfire code. Thanks to the tech articles I don't have any worries about being able to get to the coil, but I wanted to confirm the cylinder order. If I understand correctly, from front of car 1 thru 4 on passenger side and 5 thru 8 on driver's side. If that right? I don't have any way to check the coils, so I'll try to just change the offending coil first.
2. Should I expect to find a cylinder head oil leak? Several of the threads I was able to find mention oil leaks causing coil failures. If no oil leak, then replacing the plugs and coils can't be any worse than on my '99 Expedition I figure.
3. If the air cleaner isn't pretty new, then when you accelerate very hard (meaning I'm driving and not my wife
), the A/C quits blowing cold air until you actually pull over and turn the car off for 10 or 20 seconds. Then when you turn the car back on it's fine again. This doesn't seem to occur with a newer air filter. Any thoughts on this?
Thanks,
Duke
Thanks,
Duke
