2001 lincon ls v8 No 5th gear
jpwetsch
Brainard
no 5th gear took to local dealership they said codes p072 p0735 and p0760 they said I need a new valve body. With everything I have read with problems from springs to solenoids what should I believe? and if it is valve body can't I just install a kit? I need help please!!!
P072 is not a valid code. It is missing a digit.
P0735 (incorrect gear ratio) could be the valve body, the solenoid assembly, or a much bigger problem.
P0760 is an electrical problem with the solenoid assembly. It could be the PCM or the wiring instead, but it could not be the valve body. Replacing the valve body won't fix this.
Are you sure they said valve body and not solenoid assembly?
sorry other codes was p0732 and yes valve body says they performed pin point test and monitored pids- found valve body faulty.
