2000 TC blower inop
robinrules
usa
Hi,
2 months ago I replaced the blower motor because of a loose connection where wiring goes thru the morot housing. All was fine til recenly it stopped working. Tested fuse, have 12 volts to black wire to motor, but do NOT have ground to the orange /blk striped wire side. Checked relays. ok. replaced the blower speed controller as the ford tech said that was what controlled the ground circuit side. It works on high speed only if I ground the oranged/blk strip wire. Any advice? Thanks
is there a way to run a self diagnois test on this model?
