BMALDONADO7
I have a 2000 Lincoln LS. It idles rough, hesitates, & misses. Runs good at higher RPMs. The check engine light is on with a PO300 code(random cylinder misfire). I took it to the local shop which first changed the fuel filter, then tested the injectors, and replaced the spark plugs. The mechanic also claims to have checked for a vacuum leak with a "smoke machine". He said this would have also checked the PCV valve. The car still runs the same, no improvement. After hundreds of dollars, the mechanic can't figure it out. Can anyone please give me some solid advise? I am not even fixing this car for myself. I am giving the car to my brother-in-law who is a Purple Heart recipient with the Marines. He just finished his enlistment after several tours in Iraq & Afghanistan. I am giving the car to him so he can go to college and start his new life. Any help at all will be greatly appreciated. Thanks.
