cirelle
The following symptoms were fixed in my case by replacing the battery.
Hopefully this might help someone else because my initial thoughts were the car was falling apart just by sitting in the garage
2000 LS V8 Sport 126K miles
The following symptoms occurred over an approximate 30 day period in mostly city driving and under about 600 miles total driving.
Symptom #1:
Car would drive fine till stopped and turned off at destination, in this case to buy cigars which took no more than 10 minutes.
Get back into the car and it would just turn over and not start.
Temporary remedy, get out, using the key lock the door, set the alarm, then unlock the door
Get back in and the car would start.
Symptom #2
Car would die while driving for no reason.
* All lights in the instrument cluster would light up as they would when first starting
* Some lights would illuminate others would not
* Message center would indicate Check Adv Trac or Gear Select Data Error (appearing to be erroneous)
Car would restart in Park or Neutral and run fine until it stalled again, usually in a day or 2.
Symptom #3
Message center MPG would drop to 0 MPG then gradually return to a usual MPG reading after several miles. This would happen periodically
Symptom #4
At low speed when cold, transmission would want to down shift (under no load or acceleration), there would be a slight rev in the engine (as the engine was not in gear), letting off the accelerator would allow the transmission to re-engage. Within several miles, the car would die as in Symptom #2
Symptom #5
Alarm would inadvertently set while car was unlocked. This would prevent starting until the car was locked and then unlocked. Similar to Symptom #1
Symptom #6
While driving at night at low speed (30mph), turning on the fog lights would induce stalling.
Symptom #7
Locking the car would result in the locking sequence (noticed by clicking sound) would repeat until the car lock was initiated again, then would finally lock.
Symptom #8
When unlocking the car from fully secured, locked and alarmed, not all lights would blink. Typically the rear lights would blink but not the fronts (in my case) and no horn chirp.
Symptom #9
Charging the battery (4 hr 10A quick charge) would last just over 1 day. 2A over night charge would last about 2 days then one or more of the above symptoms would start occurring again.
Symptom #1:
Symptom #2
Symptom #3
Symptom #4
Symptom #5
Symptom #6
Symptom #7
Symptom #8
Symptom #9
