its a lot to read, i know. but there's a lot to say. giving as many details as possible to help quell some questions to find a solution faster. (i really want to drive my car without worrying about her)
also, even with all this, no check engine light, or even pending codes.
i have my hands full gentlemen. i bought (rescued) my beautiful black gen 1 from the hands of a complete ass. i bought it with an almost dead battery, misfire on 4 cylinders, and numerous other small odds and ends. little bit of damage to the bumpers etc. i limped it home, popped open the hood and got to work immediately. i started replacing coils one at a time (over a period of time), found the valve cover gaskets were shot and replaced them,with the help of a mechanic friend, also found out that the hydraulic fan stopped working with his very astute observation of steam blowing out the hood while he was testing some other issues. replaced the actuator because we saw that it was an extremely common issue, flushed the fluid, bled the air out, and to little progress, the fan spins very slowly. so i bought a hydro. fan motor and its currently awaiting installation. its had a huge problem with going into limp mode, randomly misfiring, high idle and excessive run on. i will be replacing the remaining 4 coils, as well as all 8 spark plugs (already have the parts) and i have already replaced the throttle position sensor, as well as IAC valve as i found those are also common trouble spots. i have a scanner, and my computer is reading throttle position of 22.4% at idle with the newly installed, brand new TPS. engine still averages about 1200 rpm at idle if not slightly lower, but not by much, most guidance was given by my friend who is a fairly seasoned mechanic. although his guidance (guesses) have been yielding little to no positive result. so im just gonna use my brain and do it myself. i know the car better than he does anyway. which isnt saying much. slow cranking, hopefully due to a starter on its last legs (just replaced battery a month ago) so no problem. alternator tested fine including resistance.
NOTABLE MENTION- engine has been swapped.
could it be that the computer hasnt been calibrated to this specific engine? if so, then i'm an idiot. but i didnt think it would cause such a large assortment of issues.
any assistance would be appreciated. im pretty competent with a wrench, and i know my way around an engine bay, and what i dont know, i research ad nauseum. so any bit of info you can help me with is greatly appreciated. i'll answer any questions or comments as completely as i can.
