1998 Lincoln Mark VIII engine parts for sale
topher5150
Grand Rapids, Michigan
Crank shaft (with oil pump)
Cylinder Heads (left and right)
Air Intake Tube
Fuel Injection Rail
Intake Manifold (upper and lower with EGR valves) x2
Exhaust Manifold (left and right with 02 sensors)
Timing Chain Cover
Under Intake Coolant Tube (both pieces)
Metal Plate (the one that goes between the engine and trans)
Exhaust Manifold Connection Tube
Oil Filter Housing
Motor Mounts (left and right)
PCV Vac Hose
Engine Wiring Harness
Oil Pickup Tube
Timing Chain Tensioners
Harmonic Balancers x2
IAC
Throttle Body
Master Cylinder Vac Hose
Cat Valve? ( mounted in front of the harmonic balancer)
Power Steering Bracket
Throttle Cable
Air Filter Box with K&N panel air filter
MAF housing
Fire Stone Blizzak Snow Tires with Rims x4 (low mileage)
Make me a DECENT offer
1998 Lincoln mark viii
If it is still available, how much for the oil filter housing delivered to tennessee?
Fuel Rail?
Hi Topher,
Have you still got the fuel rail for sale?
Is it a left side hook up?
What price would you want shipped to 05445?
Thanks for a PM.
Best,
VIC
