RONINASAUNA
Have a beautiful 91, 28k original miles, never touched, always garaged kept. This car never saw rain or snow
Everything runs fine as I baby this car .. no problems at all.
All of a sudden I put my left turn signal on, was sitting for 30 seconds at a red light and ......beeeeeeeeeep! continuous alarm clock noise. I first thought that I had set the alarm (which I have never done since I owned the car) I tried to reset it, but was never set. I disconnected the battery, reprogramed the clock.
Restarted the car and thought nothing of it as the clock alarm sound went away for that day.
The next day while idling at a light again (this time without a turn signal on) the clock alarm sounded again and will not shut off. Any time the car is started or the key is in the "run" "on" or "acc" position the clock alarm sounds as long as all the doors are closed. If any door is open the clock alarm shuts off.
I am stumped as to what to try next. Possible mulitfunction switch? all other systems operate normally. Center console control panel? Every item of the control center functions normally. I do not have a "known good" switch or control panel to "try" and am all out of ideas..
Any suggestions as to what to do/check? I have done search after search on the net and couldnt find a thing. I would even go so far as to disconnect the clock alarm function if I could locate where the speaker for it is...
Thanks much in advance for any help
