100 MPH Mark run
Thanks they were like 40 bucks just a high gloss stick on with needles I painted
I need to play around with the settings the video is suppose to be HD but doesn't look like it now.
Needs boost. :shifty:
I like the white face gauges..even tho I doubt they'd fit my Black out theme. I want to pull my gauges and repaint my needles a sharper blue, not so much sea-green. Wish there was a way to redo the info center the same way
It's HD. It takes time for YT to render the upload.
How ya been man? I got a new facebook you should pm me your email address. ;)
I was trying from my phone and it looked horrible. Now its fine. :rolleyes:
I was wondering where you went. I'll PM you the link to mine. :Beer
Lol yeah man, had to switch it up...better to just start fresh. Tried searching for ya but couldnt find you. Been like 3 weeks now. :shifty:
Love the sig BTW...is it bad I remember each one of those cars from stock, to modified, to finish...
I remember stripping cars together in like fuggin maryland or some chit to make ours super fresh.. hahah those were the good old days. :D
blue needles would look good. I went with an orangish red to match my autometer phantom guages.
I think the white guages look GREAT on a blacked out car...livens up the interior alot, but to each thier own.
Hahahaha...you can hear 3rd gear chirp the tires at the 75mph shift on the video...everyone always calls BS on my auto trans doing that...not anymore lol
Good stuff. :D
What is 'much more'?
Little things, all maintenance done on it - Motorcraft plugs, Mobil1, motorcraft filters, and parts are always used, rebuilt the front suspension, evacuated AC system, Coolant, trans, rear, etc. Motor is 100% stock right now.
1997 Lincoln Mark VIII Black on ebony black LSC, heated seats, moonroof.
100% stock ran 14.9 in the 1/4 @ 93.3 currently has 97, about to turn 98K miles on it. Was purchased in 2008 with 54K miles from the 2nd owner.
Up to date modifications include -
SCT Xcal3 Tuner with tune from Torrie @ fastpartsnetwork
Cobra Rear Diff Housing powdercoated sparkling silver with;
4.10 Ford Racing Gears
Eaton True Trac Differential
LPW 8.8 Girdle Cover
ARP Stainless Bolts
4" HD aluminum Dynotech Driveshaft
K & N Panel Filter & Air Silencer Delete
Xpipe Installed & 3rd Cat Removed with LMS mufflers
160* MotoRad Cobra Thermostat
Stock 97 Trans with Mercon V;
JMOD drilled to highest setting,
all springs left in trans,
new accumulators
Hubswapped & Brakes;
Ford Racing Cobra Rear Hubs & Timken Front Bearings
13" CrossDrilled/Slotted Cobra front rotors
11.6" CrossedDrilled/Slotted Cobra rear Rotors
2003 "10th Anniversary" Red PowderCoated Cobra front Calipers
New Ford Rear MarkVIII Calipers, Painted red
Rear Caliper Relocation Brackets
Red Stainless Steel Braided Brake lines
New OEM Ford Axles
Wheels;
18 x 9 & 18 x 10 Saleens with 2005+ offset
Hankook Vetnus v12's -
245/45 Front & 275/45 Rears
Exterior & Body;
Fender Rolled
All body work recently finished, awaiting paint
5% Rear Tint, 2.5% Rear 1/4 Windows
8000K Aftermarket HID's
Interior;
3 Pillar Lotek Pod
Autometer Phantoms
White Glossy Guage Faces, Red needles
Kenwood Double Din Headunit
2 Polk 12's
2000 Watt Class D Amp
Just removed all my air ride stuff;
ASHAM8 (NIB)
Spider Extreme V3
AAS Rebuilt compressor
I'll miss it...but If i decide to go back to air one day, It wont be on the stock suspension.
Saturn's Long Braces & Rear Diff Brace getting Installed next saturday
Have a temple bumper, like new halogen headlight housings, and a sleepy valley ground effects (not sure what i'm doing with that yet) laying around for when its time to paint.
Need to fix the rear neon and the blend door, will probably do that this winter, pull the dash, install the pedals, relocate the ecm and hopefully the battery to the trunk. Lots of work left..but slowly been trying to build it to my tastes.
