ONEBADMK8
This is made out of cold rolled steel and is of tubualr design, not square or rectangle like the "others" are.
Its also much more stable and rigid then the "others" because of the straight run engineering, with NO turndowns and multiple piece portion from plate to plate. Ours is rock soild with the tubular tension bar directly welded to the massive 3/8 in cold rolled steel plates.
NO turndowns, NO multiple pieces, NO MOVEMENT!
You will be purchasing this unit in black high gloss powdercoating along with NEW grade 8 steel hardware.
$59.99 FREE installation at May 1st meet.
