1.5" conversion
Lownslowlsc
N il
For both front and rear how many fingures verticly can you stick between the top of the tire to the lower fender?
Also, is the front airbag suposed to be fully inflated?
on mine, I get, two or three fingers in front, 3 or 4 in the back-depends on when I check it-if when I first start it, it's a little higher, when you get out and close the door, it vents and goes down a little. I did redrill the front sensor brackets so that I could adjust it lower, and that did drop it a decent amount IMO. the bags look full when they pump up, I guess there's 'more-full' if the sensors are set higher.
What i meant was for the conversion kit. How many fingers front and rear.
i barely got 1 or 2 after the conversion.. but i had 18's.. so that might make a difference
it started off higher when first installed.. then settled a little lower after a few weeks
